Nitrogen fill
There are several compelling reasons to use pure nitrogen in tires.
N is a larger molecule than O2. Tire pressure will remain more stable over time, since N is less likely than O2 to migrate through rubber.
Do you check your tire pressure daily? MSF wants daily pressure checks.
Have you ever seen or felt moisture/ water (H2O) in your tire? (I have when purging the schrader valve of dust before adding air). Water causes even larger pressure swings.
Do you drain your compressor of water regularly? I don't. When I do, lots of water drains out. It is VERY easy to get water in your tube or tire, I have seen this often, been riding and changing tires for 40 years. I remember finding water in my bicycle tubes as a kid, most likely from the gas station compressor I used.
I think N is a great idea, but I don't use N due to cost and hassle. I just use air from as few sources as possible to avoid water.
How about a link with the FACTS: http://www.popularmechanics.com/cars...a3894/4302788/
Very well said. Thank you for that reply. I never thought about the moisture as much as I did with the wild swings in pressure that I see with regular air. Thanks again for that information.
Another reason: Jet tires
I have flown Boeing and Douglas jets for over 30 years. My company uses only N in the tires.
For the reasons in the link above and one more: A brake fire is fairly common after a high speed rejected (aborted) take off. These fires can be common after a high speed emergency landing when minimal or no flaps are used.
N is also inert, and will not feed the fire like O2 can if the brake fire consumes the tire. BTW, there are fuse plugs in the rim to deflate the tire when overheated to prevent an explosion. B-767, DC-9 main tires used 195-205 Psi on the mains. Tires are rated to 195 Knots!
Lots of vids on youtube:
...Have you ever seen or felt moisture/ water (H2O) in your tire? (I have when purging the schrader valve of dust before adding air). Water causes even larger pressure swings.
Do you drain your compressor of water regularly? I don't. When I do, lots of water drains out. It is VERY easy to get water in your tube or tire, I have seen this often, been riding and changing tires for 40 years. I remember finding water in my bicycle tubes as a kid, most likely from the gas station compressor I used...
Not saying N is bad for tires, by all means, if you can afford it and it makes you feel warm and fuzzy put it in there... Remember to check you pressures often... Do you ride over to the outlet (Dealer or tire place) to get refills to keep it pure N or do you fill from another AIR source?
If you can get 100% nitrogen for free, then go for it. I don't think it's worth paying for, I have an air pump at home and just check my pressure weekly.
With 100% nitrogen, the pressure still changes with the air temp. What nitrogen and really and "pure" gas element offers is a predictability of the pressure change to the air temp.
As you ride, the tires warm up and the pressure increases.
