buying tires for my new wheels but there is contaversy
Old 11-25-2015, 09:57 AM
Cheath31's Avatar
Cheath31
Cheath31 is offline
Default buying tires for my new wheels but there is contaversy
So its time for tires on mt 02 stock heritage but this time around, Im going with a 21 x 3.5 chrome wheel up front and a 18 x 4.25 on the rear. Ive read several places that a 160 rear wheel would not fit but the 150 would with ease. Has anyone seen a 160 on a heritage?
As for the front does anyone have any recommendations as to what size would be best. I do have charts but wanted to see if anyone has any first hand theories.
Thanks in advance
Old 11-26-2015, 10:20 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
It doesn't matter which big twin model, all of them from the era of your bike have the same challenge. There are two limitations on installing non-standard tyre widths, fender width and clearance between tyre and belt. Your rear fender isn't much wider than most 160 tyres, so getting one in your bike is a gamble! As for your drive belt, if you have the 1 1/2" wide belt then in my experience the widest tyre you can get in is a 140. I've read that a 150 will fit, but the only way I got mine in was by changing over to a narrower belt and rear pulley.
What does your wheel supplier recommend? If you don't get any satisfaction with them or in here, post in the Softail section, where you should get more hits.
Old 11-27-2015, 08:47 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
For the front you want to run a 120/70-21 tire. On the back the widest you can run is a 150....been there, done that. As mentioned, with your 1.5" belt your clearance issue lies there. A 150 tire is damn close to the belt too, but it works.
Jon.alvarez4
05-26-2017 09:49 AM
HOGILAC
03-03-2015 09:20 PM
rkc9999
09-27-2013 03:57 PM
JIMSFBL
09-09-2011 11:22 AM
HGM
EVO
04-30-2010 08:18 PM
Quick Reply: buying tires for my new wheels but there is contaversy
