Help!...Rear wheel install on a 2011 Dyna Wide glide
Old 04-18-2016, 11:07 PM
Bikz's Avatar
Bikz
Bikz is offline
Default Help!...Rear wheel install on a 2011 Dyna Wide glide
Hi guys,
I took apart my bike to powder coat some parts. I jumped the gun and pulled off the rear sprocket off not paying attention to:
1. Either wheel spacer (they have grooves in them)...my manual does not mention "grooved" spacers
2. The rear wheel alignment adjusters.
Unfortunately, I went to install the wheel today and im afraid the spacers are facing the wrong way (I have them facing the bearings) and I'd like to avoid buying the HD tool for aligning the rear wheel (since I screwed them all the way in to take off the belt). Your help would be much appreciated!
Thanks in advance!
Old 04-20-2016, 05:29 AM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
The longer spacer goes on the left/pulley side, the grooves toward the rear fork/swingarm. The shorter spacer goes on the right/rotor side, grooves toward the caliper bracket.
It's a better idea to be certain of your rear wheel alignment, you can make a simple alignment tool out of wire or you can pick up a #08-0368 Motion Pro rear wheel alignment tool inexpensively from Amazon or eBay...
cvaria (04-22-2016)
Old 04-20-2016, 06:53 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,235 Likes on 1,811 Posts
Originally Posted by Bikz
...Unfortunately, I went to install the wheel today and im afraid the spacers are facing the wrong way (I have them facing the bearings)...
Yeah...Don't worry about that. Hopefully if you have OCD, it won't get the better of you on that NON functional difference.
Old 04-22-2016, 09:08 AM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
bought MP alignment tool just now, thank you.
Old 04-22-2016, 09:17 AM
multihdrdr's Avatar
multihdrdr
That's was a relatively expensive piece of "Coat Hanger"
Old 04-22-2016, 09:55 AM
TinCupChalice
Well, sure... you could make it out of a coat hanger... but, TOOLS!
I could have made a fork seal driver for my 49mm forks but the Motion Pro 49mm fork seal driver is so purdy, I couldn't resist
Old 04-22-2016, 10:16 AM
multihdrdr's Avatar
multihdrdr
Tru Dat
That being said...I've never gotten these to work
Old 04-22-2016, 11:19 AM
TinCupChalice
Yea, those plastic hangers aren't much good out in the garage, are they? This thread has me suddenly thinking about Joan Crawford!
Old 04-29-2016, 09:37 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
I made mine from24" piece of 2"dia pvc pipe... works really well, and cost about 3 bucks...
multihdrdr
04-28-2017 11:26 AM
Dhock83
Wheels/Tires
06-27-2016 06:41 AM
rob0225
06-22-2013 07:11 AM
drspencer
05-17-2012 03:01 AM
darenweir
10-12-2006 05:25 PM
Quick Reply: Help!...Rear wheel install on a 2011 Dyna Wide glide
