Wheel swap
Wheel swap
I have a 2012 street glide without abs. I bought a 2014 street glide front wheel with abs. Has anyone done this before. I could use some help. The abs bearing I removed is .706, the non abs bearing is, .588. I bought a spacer that fits from 08 up which is .187. As you can see this does not add up. Thanks
My above info is still true, but I just re-read your original statement...
"I have a 2012 street glide without abs."
and could have simply said "Re-use your original spacers"...same thing
Also you may want read this...good info
https://www.hdforums.com/forum/wheel...ientation.html
