Enforcer 19" Front Wheel Swap Questions
Hi I am new to the forum and just recently upgraded to a 2008 Road Glide without ABS, I just purchased a 19" Enforcer Front Wheel Take Off from a newer bike. While doing some research I found that the abs bearing has to be swapped out to HD part # 9276 A which is a non abs bearing, for the 25mm axle. I was wondering do I need to order two of these bearings or is there another HD bearing that goes in the wheel that is different? Any help would be appreciated.
Thanks
Thanks
You can either use the 'new' wheel as is and buy an abs axle spacer to replace your current spacer, or swap the bearing. If swapping the bearing you may need a new spacer tube (for inside the hub). There is a Sticky at the top of this section on using an 18" wheel, check in that for more details.
You may find that the Enforcer rotors are larger in OD than yours, so do check that you can get the correct OD rotors for your bike, as the later style are not suitable, due to being too large.
