Rear Tire wear - one side
Noticed a little more tire wear on the left side of the rear tire, not the extreme left , but the left just past center of the tire.
I have several K mile on it so whatever it is it isn't extremely wrong.
My first guess is that the rear axle might need some adjusting. Just trying to determine which way to go with it.
Sounds right.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Due to the pipes on the right, softail riders typically don't lean as much on right turns. Along with what the others have said, if it applies, it's still a good idea to check the alignment. If you can get a good, straight 2x4 or similar, lay it against the rear tire's sidewall, as high up as you can, and see if it ends up parallel with the front tire, and adjust if necessary.
A Softail rear does not align with the front with adjustment. The rear adjusters aligns to within 1/32 of the swing arm bearings but mostly to the front drive pulley. (when correct, the belt will rub lightly on the flange on the rear pulley) The front aligns with the rear with the handlebars.
