ABS, non ABS bearing clarification
Swapping ABS Enforcers on my non ABS '13 SG. Got everything figured out in my brain except the bearings.
The way I understand it, I can either just use the ABS bearing, and all my original spacers and call it a day, or use a non ABS bearing (with spacer behind it)???
And since I don't have an ABS bike I wouldnt know, but what about the rear bearings? I didn't see too much mention of that anywhere really. Same deal as the front?
I'm thinking its prolly easier and faster to just spend the extra 40 bucks for the ABS bearings front and rear and run them than trying to turn spacers on a lathe.
Thanks
Thanks
Ok, bottom out the non-abs bearing in the deeper bore (unless the bores are the same and I got wrong info) of the ABS wheels then and use my original spacers. Easy enough. Thanks!
Regardless of shallow or deep, the wheel usually will have an indicator to which is the "primary bearing" side such as a machined circular groove on the rotor mounting surface.
Again,in your case...
Don't touch anything on the wheel, but use a reduced length spacer against the ABS bearing to run the wheel on NON ABS bike
OR
Change the Bearings and then run your original spacers
OK, Thanks for the help guys. Haven't pulled the wheels on any ABS bikes yet, I started thinking that there might be a difference in the wheel on the ABS side. Even though I knew they can be used. I'm opting to change the bearings in the new wheels and run my original spacers. My little bit of confusion arose because I figured the ABS bearing would need bottomed out in order to maintain sensor gap.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
If so, how many miles?
EDIT: did you say you had a lathe?
