Confused . I need an axle please help
Hi guys.
I bought a used flstF front end to put on my bike.
I was told it was 84-99 .
I ordered an axle for a flst but it doesn't fit into the hole so I can screw the nut on. It's not huge like it's clearly the wrong axle but it should slide right in correct?
Iam confused.
I have the front end on my bike but I do not know what to do able an axle.
Can anyone she'd some light on this for me.
Iam confused.
Pics in this situation would help a ton. IF your front end is from an EVO FL Softy, you will need a 3/4" diameter axle, what size do you have? What years are the axle you purchased supposed to fit? 84-99 is different than 00-06. Could the package be correct as far as the label goes and the product inside is wrong (I see this often at the shop)?
