2015 Enforcer on a 07 RK police.
I know that this has been covered in other threads but I'm not sure I have all the information needed to complete this.
My questions are 1( my 07 has abs, what do I need as far as the abs is concerned to do this. 2( can I use the 1" axle and bearings then bore the new wheel spacer and sleeve.
just for clairification I have a 2007 Road King Police with ABS, I have an Enforcer wheel off of a 2015 Road Glide with the rotors calipers and brake lines.
Someone would have to do some custom work to be able to re-use the 07Police ABS "Tone" ring on a wheel that uses a "Spoke Mounted" rotor (Enforcer)
Thinking outside the box...I have some ideas...but again custom work.
Hey, just though of this...
You could use an Enforcer from a "Freewheeler" Trike. They use a traditional "Hub Mounted" rotor. You would remove your 07Police ABS "Tone" ring from the existing 11.5" rotor and re-install it on a new 11.8" (drilling new holes with new rivets or maybe another fastener)
- You can use all 25mm stuff
- Use your 1" axle with aftemarket 1"ID x 15mm wide bearings and 08-later wheel spacers enlarged for 1" axle with a 08-later center spacer sleeve
- Use your 1" axle and OE 1"ID x 21mm bearings with "Custom made" spacers and a 08-later center spacer sleeve
**The bearings will protrude slightly...approx 1/16" Left and 1/8" Right
BALLS172
04-05-2014 07:09 AM
