Wheel fitment
It is very likely it is a swap for your bike, however it has #9267 bearings, whereas yours has #9247. I think your bike has 1" ID bearings, while the softails used 3/4". I have a softail cast wheel in my Glide, which fits just fine, after I swapped to 1" bearings. However I had to bore the central hole through the hub, to take the larger OD internal bearing spacer.
H-D sells a kit that includes a pair of 1" berarings plus the correct spacer tube, which I used. So it will probably fit, but you will have to spend a little effort and cash to make it do so.
Besides needing to enlarge the center of the heritage wheel for your 2003 1" axle/spacer sleeve, the heritage has a slightly different offset than the RK wheel.
The wheel will sit more to the right than your RK wheel does now by approx .09-.100" (You gain that space on the left and reduce it on the right so it has the appearance of more movement) That may be OK for you
