Are there any special tricks to removing the front wheel of my UC? I dented my front fender and need to remove the wheel to get the fender off. I've just never done it before and I'm nervous about operating on the front end... It looks easy, but I know that isn't necessarily the case. Other than a torque wrench I'm not sure if I need anything else except someone's exceptional knowledge in this area!!!
Nothing special about tearing it down, it's putting it back together. A manual would be handy for re-installing the front wheel and calipers. I believe you will also need a 10mm 12 point socket to remove calipers.
+1 with Chester, the hardest part (and it's not that hard) is getting the calipers off and on. Pretty easy job. And a manual is a must for any job, great detail.
