I'm wondering if I can insert the rear axel on my '08 heritage from the left side instead of the right...
As it is now, every time I want to pull the rear wheel I have to remove, or severely loosen my rear muffler... If I put the axel in from the other side I won't have that problem.
I don't see any problem with the idea but thought I should ask here as some of you guys have a lot more information than I....
Thanks... I went ahead and did it... I couldn't think of any reason not to...
Perhaps the thinking on the way it's installed was safety/redundancy, that with the exhaust effectively trapping the axle, it could never fall out by itself, even if the nut fell off (why they add a snap-ring outboard of the nut on some axles).
On Dynas, simply disconnecting the shocks allows enough drop on the swing-arm to remove the axle. Not sure what's normal on a softail.
Yeah, same here. I did it years ago on an FXR. It's such a no-brainer that it spooks you into thinking you might be doing something wrong. Like when the computer asks, "are you SURE you want to delete that file?" Uhhh, I dunno computer, what do you know that I dont?
This cracked me up! or i just gone crazy from lack of sleep!
