rotor runout warranty or not?
I have the maintenance manual, and according to page 1-33, the max brake disc lateral runout on a 2009 Ultra Classic is 0.008" measured at the outside diameter or the rotor.
If the bike is still under warranty, are these parts covered under the unlimited warranty, or is it like spark plugs, an expendable item??
If it is not covered under warranty, before replacing the rotor, you can try to straighten it. Get the wheel off the ground. Use a dial indicator to find the high spot and tap lightly with a leather (or rubber) mallet. Re-check. It may take a few minutes, but I have had success doing this when the rotor is only slightly out of spec.
Specification
.115 runout? You'd have to run into something to make it that bad! And you wouldn't need a dial indicator to see it.
I have no ABS experience. The .115 runout is not too far to tap back not spec. If you do replace the rotor, you can replace only the warped one. No need to do both. Just be careful not to damage the good one when you are working on the warped one. THEY BEND EASILY!!! Lay a couple 2x4's on the garage floor and place the wheel on them so that the good rotor does not touch the floor. If you do replace the rotor, use new bolts. Do not re-use the existing ones. When you buy the new bolts, they will come with the locktitealready applied. Torque them to spec.
I think I would have remembered if I ran into something, but I did have the front tire replaced twice in 14K miles. Maybe when they removed the tire, they bent it, I don't know.
Tap tap whack
The wheel however now spins more freely without the "easy then hard" feeling I had earlier. I decided to wait until I could ride it and see how it feels before I do anymore tapping.
Thanks for the tip on taping it, that was good advice. Thanks
