Rear brake premature pad failure, and no bubble from pressure relief port?
Guys at first I thought my caliper might be at fault. Then I read in the service manual about checking for the presence of a bubble when pressing the brake. I'm not sure if this is my problem. I searched the archives, and it sounds like guys are having severe brake lock up issues associated with no pressure relief bubble.
What do you guys think? Anything else that can cause premature pad wear? Is there a way to clean this port out?
Yea I read about that. I already have a new caliper, brake line, and rotor that I haven't installed yet. Just wondering if I should replace or rebuild the master because I don't want to overheat/score another rotor if the pads wear through again. Pads are lasting about 2k miles. Seems to be lasting longer as time rolls on. It's been this way since 08
Definitely rebuild the master cylinder. Brake pad wear, lock up etc happens because the master cyl piston does not return to its full out position. That blocks the port you would see bubbles from. A heat builds, it expands the pads out tighter onto the rotor, casuing premature failure.
I had a brand new out of box front master that wouldn't return properly, but it never got the chance to fail,it would not produce any flow, basically blocked itself. I installed a new kit and the problem was solved. Fastrider 124
Same thing is happening on my bike right now. I noticed reduced gas mileage and very hot rear rotor. I pulled the lid off the rear master cylinder and see no bubble when I push and release the brake pedal. Ordered a new rear master cylinder for $75 from Newcastle HD in Pennsylvania. Just waiting for it to come in. I hope this solves my problem so I can get back on the road.
I have never changed the brake fluid on any vehice I've ever owned but I guess I see now why it's important. I will be doing it on the bike every year or 2 at least from now on.
Okay guys, this is what I did so far. All at the same time. Bought the new cartridge for the master. The fluid was dirty with much sludge in the reservoir blocking the relief port. I now have the bubble.
Just a heads up the pushrod snap ring is a two man job.
I flushed the fluid with my Mitivac, and bled it the old fashioned way. Brakes went soft after a day of riding. Bled it again and got another bubble out. Hopefully It's all good!
