Bad Front Bearing, Replace as a Pair?
At 23K I just changed the 2nd front tire on my 09 FLHT. When balancing I noticed a slight bit of play in the right bearing. I did a search and saw many people are having failed wheel bearings. I've never changed a wheel bearing before so I was just going to take it to the dealer. My questions for any of you that know; should I just have them replace both while they're at it? My hunch is that is what should be done. Is there a better bearing out there?
Pay out of pocket if you have to, most dealers will or should do the labor under warranty, but you will have piece of mind at least with a better bearing. I know I did, less then $20.00 a piece depends where you go and if you get a discount. SKF is the way to go. the stock bearings are made in China or Korea I forget now, but not in North America for sure.
Change them both if your going this way>
So I guess you're recommending "SKF" brand bearings as being better? If so I should probably order a set for each wheel and have them installed next tire change.
It's not where the bearings were made but how they were designed. '00 to '07 had double row bearings ( 21 mm wide,) that I replaced at 100,000 miles just for good measure. There was nothing wrong with them. Their replacements were made in China, and no problems.
In '08 Harley went with the cheaper 25 mm axle set up with cheaper single row bearings ( only 15 mm wide,) and that's when the bearing failures occurred. Many were delivered w/o enough grease in them, on top of being a poor substitute for what they had previously.
And yes, I'd replace them both.
Thanks for the explanation, Stiggy.
So I now have two motorcycles with known bearing issues. BMW's F650 Twin is the other one.
Part numbers please
Do any of you have the SKF part numbers plaese.
My bike is a 09 FLHR.
thanks
signed....REDHEAD
6205 2RSJEM is the number on the SKF.
The 9276"A" for HD's "problem fix" on the chinese made bearing is out now and better reports from them (probably put grease in the bearing)
thanks
signed....REDHEAD
oh and same bearing number on a Goldwing and they are pretty heavy and if you talk to a Honda dealer they don't have much trouble with there's, so something's not working right in quality control with SD bearings in China.
