dot3, dot4 what is the difference
The DOT number i believe refers to the boiling point of the break fluid. If something is DOT 4 then it can also be used in a DOT 3 system, putting both DOT 3 and DOT 4 on the bottle makes it more marketble thats my guess. I wouldnt have a problem using the autozone stuff that says DOT3/DOT4 but thats just me.
My rear master cylinder on my Harley blew a seal and start pissing break fluid everywhere one day when i was out on a ride leaving me with no rear brake. all the gas station had was DOT3 (bike calls for DOT5 synthetic brake fluid) having no real other option i put in the DOT3, enjoyed the rest of the days ride and made it home safe without any issues until i was able to fix the seal and swap the fluid out.
hope this helps
hope this helps
Oh ****, i hope that doesnt happen to me. I mean after i got home i replaced it with DOT5 and then after bleeding the system i imagine most if not all of the DOT3 would have been pushed out.
DOT 5 is not compatible with any other type of fluid. If you have used DOT5, but your system should use DOT 3 or 4, I really recommend you strip and clean before using the correct stuff. At the very least flush out using a suitable brake flushing agent.
jhogan20
06-19-2008 06:14 PM
Paul G
01-02-2007 10:09 PM
