DNA Mammoth issue, help needed please
Old 10-28-2012, 02:52 PM
redmosquito1's Avatar
redmosquito1
redmosquito1 is offline
Default DNA Mammoth issue, help needed please
2012 Deluxe
Got my new DNA Mammoths friday rear mounted up great, easy as could be and no need for a pulley spacer.
Front not so much. 1st issue was it came with 1" bearings and my Luxe uses 25mm axle. Determined this when I went to install the wheel the spacers were super tight and the rotor was off to the right about 5mm or so. With help of a fellow member they directed me to the difference in 1" and 25mm bearing being the 1" bearing is quite a bit thicker than the 25mm bearing.
So off to the local indy to have a set of 25mm bearings installed. Now the spacers work fine but the wheel is offset to the left to the point I can't get the caliper on the fork. Also the wheel itself is offset in the fender to one side.
Using PVC to make some mock up spacers to center the wheel in the fender I'm not able to get the rotor to line up with the caliper.
Wondering if this is an issue more involved than just swapping the bearings, possibly DNA sent out the wrong hub, like for a touring bike instead of a softail. And if their was anyway of telling.
Old 10-31-2012, 05:43 AM
HD32141's Avatar
HD32141
HD32141 is offline
Have you spoken to DNA tech?
Old 01-22-2013, 09:48 PM
HDwildcat's Avatar
HDwildcat
HDwildcat is offline
Default DNA issues
Originally Posted by redmosquito1
2012 Deluxe
Just wondering if you got your wheel issue straightend out. I had similiar problem with DNA on front wheel for a Superglide. Also had issues with the belt pulley.
taterbum
Wheels/Tires
09-12-2015 11:19 AM
johnod
EVO
04-15-2015 01:39 PM
machm1969
01-18-2014 09:23 AM
redmosquito1
10-28-2012 07:17 PM
gtrplyr
03-18-2012 08:22 PM
Quick Reply: DNA Mammoth issue, help needed please
