Front wheels on Roadking
I have the 21" on the front of my 04 RK Custom and taped a 1/4" nut to the tire and it did rub so I simply redrilled the aft fender mounting hole a little bigger and lifted the rear of the fender up as I tightened the fender bolts. Be sure to use locktite on the bolt if it comes loose you can burn the paint on the fender also use tape over the hole before drilling so you don't chip the paint. I love the look of the 21 in the original fender.
