Air leak around base of valve stem
Hi,
I found some info on this by searching but wanted a more definitive answer if it exists.
Front wheel is a laced factory rim. Just had front tire replaced (tire, rim strip, and tube).
Rode bike home (3 miles). Next morning front is flat.
Re-inflated and soaped tire. Air bubble are coming from the base of the valve. No air around spokes, bead, or top of valve.
I'm thinking that the leak is at the base of the valve where it connects to the rubber of the tube. If it was a hole somewhere else in the tube, air would be leaking around most of the spoke nipples. It this correct?
Thanks!
Thanks!
trooper50
04-25-2012 06:11 PM
Dynaryder85
01-15-2012 04:23 PM
