XM Radio
I was looking into transferring a XM subscription to my Limited.
I noticed that the XM Radio setup is greyed out. Does this light up after I have the radio activated? Where do I find the XM Radio serial Number I need to give to activate it? |
If correct you need to add it to the bike unless unlike the street glide it came with it but I thought it was only the ultra that came with it. I had to add it to my 14 sg. Well worth it tho if you ride any distances at all.
Batman |
it only comes on a CVO ultra
have to add module on the Ultra Limited -- think they told me about 700 dollars and you have to have the dealer flash the system
Originally Posted by flyboyron
(Post 14234720)
Great thanks. I will look into getting the module first.
I thought it was like cars and trucks where you just call and get the subscription added. I didn't know I had to add a module to the bike. Thanks for the help. |
Basically the module slides into the back of the stock head unit once you remove the outer fairing. Basically what Harley did was carve out a part of the radio to be able to sell it to you for $400.
Do not pay the shop to install it. Someone here said $700 to install. Assuming $400 for the module and a labor rate of around $100 and hour (it is actually $110 at my dealership), that is 3 hours of labor. I honestly think I could install 6 of these singlehandedly in under 3 hours. Any labor quote of over 1 hour is absurd. |
I bought mine here. Simple install.
http://www.boardtrackerharleyonline.com/harley-davidson/boom!-audio-siriusxm-satellite-radio-kit-76000351 |
Originally Posted by Ganooch
(Post 14235235)
Can verify that no flash is needed. When I did mine I just powered it on and the Sirius section was added to the Home menu.
© 2024 MH Sub I, LLC dba Internet Brands
