My pleasure...I thought I might need it again to...so, I keep all of the versions that I upgraded from. If i recall, this is the forth upgrade for my bike.
I did like that new contrast screen - have to check to see if that was on the 1.18.3 version. |
Originally Posted by cycle7447
(Post 14091360)
As I downloaded the software, I kept a backup copy in my PC folder. So, all I did was put the software back on the flash drive, turn the bike onto accessory, install the flash drive and it said, upgrading from 1.19 to 1.18.3
If you don't have the software, let me know. I believe I can e-mail the zip file to you. |
I compressed the file and sent it to you from my AOL account. I have Outlook also - but it said the file was too large - even when compresses.
If you don't get it or can't open it, let me know. I can put in on a CD and mail it to you. Thanks Don |
(Post 14092017)
I made the CD - contains both the fill zip and the disk folder (unzipped). Just copy this to your flash drive and insert into your bike.
If you copy both files to the flash drive, you will not have to unzip. Good luck |
(Post 14091390)
IUOE ROB - yes, I did check - the high contrast screen is not on the 1.18.3 version.
I use the GPS function quite a bit. The distance to next turn has always counted down. On the highway, you normally get a notification at 2 miles out... then the screen counts down. |
(Post 14094744)
© 2024 MH Sub I, LLC dba Internet Brands
