Do you run an EBS
Old Jun 10, 2016 | 10:40 AM
CaptainKirk's Avatar
CaptainKirk
Originally Posted by striper.seeker
Nice. I see you have the hoses connected to the bolts. They recommended to me not to do that because of leakage on to the frame and jugs. How else would I connect them?
The hoses are connected to the banjos the same way as they would be without the external breather (venting into the intake). I just pointed them down instead of at each other. I don't see any other way of doing it......
Old Jun 27, 2016 | 09:27 PM
jungleman's Avatar
jungleman
I'm just thinking out loud here. I purchased the parts to do this conversion but did not do it.
Have you heard of water injection ? more power.
A little oil in the top end of cylinder might be beneficial, help to prevent wear.
Might keep the top of piston cleaner but is it really necessary or worth the trouble.
Don't know.
Old Jun 27, 2016 | 11:58 PM
motoXjoe's Avatar
motoXjoe
It's worth it, slightly more power, cleaner piston crowns and not that much trouble to install, an hour or less depending on the way you run the lines, and mount the filter.
Forget the H2O injection, just install the kit and enjoy the ride.
You'll notice a slight seat of the pants difference. Your bike will like the fresh air...
Old Jun 28, 2016 | 05:46 AM
lp's Avatar
lp
Originally Posted by QNman
This.
The product you've shown isn't filtering air coming into the intake; it's filtering air coming into your crankcase (when it sucks instead of blows).
It should never "suck" in through the breathers. There are umbrella valves to eliminate back-flow into the heads. The whole system only allows air flow in one direction - Out.
The Filter on the end of the bypass is just to give the misty oil some place to solidify and collect.
Everything else you stated was spot on though.
Old Jun 28, 2016 | 11:06 AM
QNman's Avatar
QNman
Sorry, you're right! Thanks for the correction.
As to "more horsepower", I would never install an external breather for "more horsepower". Assuming it increases at all in the short term, I'd strongly suggest any gains would be minimal at best. If you're engine is belching enough oil out of the breather to affect your intake charge that drastically, something else is wrong.
I always thought (like when I put one on mine mack in the day) this was more of a "long ball" move; one that would pay more dividends "down the road" by keeping the intake cleaner over time.
Frankly, as tight as new engines have gotten about blow-by in general, I'm not personally too concerned about the minuscule amount of oil I see getting into the intake. I see plenty of 100k Harleys on here with no EBT's.
As always, YMMV. Your bike, your $$... your call.
fatrob74
May 7, 2016 02:47 AM
tripleb1911
Sep 19, 2014 03:53 PM
PatoConcha
Jan 16, 2014 04:21 PM
traildog
EVO
16
Jun 17, 2012 09:44 AM
Savage223
Oil Archive (no new posts)
Jun 6, 2011 07:39 PM
