Electrical issues
Old Jun 13, 2017 | 12:26 AM
2015FLTRXS's Avatar
2015FLTRXS
Default Electrical issues
I posted about this in the electrical forum but I don't think it gets much traffic. If this is against the rules feel free to delete this thread.
https://www.hdforums.com/forum/elect...ng-issues.html
Abbreviated rundown:
Blacked out all chrome on the bike as well as installed my gauges that got customized. Less than 100 miles after all this my speedo started acting up on and off. Couple of days later my bike threw 3 codes (P1510, P2127, P2138) pointing at the throttle sensor. Since that day I went and soldered the wires on the throttle getting rid of the green plug (didn't help issue). Rode roughly 600 miles with no speedo issues.
Couple of days ago I cleaned the ECM connections as well as the throttle and speedo connections with contact cleaner and dielectric grease. The codes cleared right away and bike ran good all day, 100 miles with a couple of stops and the codes never showed. Until the next day i pull the bike out and codes are back.
My question is what changed during the 12 or so hours my bike sat in my garage? To me I can't see how this is a damaged wire issue, the codes would have popped back up while the bike was moving-vibrating.
Old Jun 13, 2017 | 09:54 AM
Hammz's Avatar
Hammz
Maybe a broken wire that makes contact most of the time? Cold overnight soak things cooled down; thermal shrinkage = open (loss of contact)? IDK.
Don't have my manuals & troubleshooting info with me here in Black Hills. Try using the service portal to access the Electrical Service Manual & trouble shoot based on codes.
Service Portal - https://serviceinfo.harley-davidson.com/sip/index - use Customer VIN Lookup tab. You'll need your VIN to access.
Good Luck!
jcboof
Jun 29, 2020 01:41 PM
foxhd
Electrical/Lighting/Alarm
Sep 18, 2015 10:21 AM
Blaven48
Jul 19, 2014 04:15 PM
ffemtbiker
Jun 28, 2009 04:38 PM
jcboof
Jul 11, 2008 12:33 AM
