Help with codes.....
Old Jul 21, 2017 | 07:55 AM
Black_Gold's Avatar
Black_Gold
Default Help with codes.....
Have a problem that may, or may not be easily solved.
Left the house yesterday for work, and all the instruments went to zero, security light and check engine light came on. Security light went off, but CE light would go off and on, then eventually stayed on. Turned around and went back home. I tried it again last night and it would start just fine, but if I turned it off and went to ACC, it would all go off and showed a code (actually 2). One was V INNER and BUSErr. From searching, I see the V code may have to do with a bad battery, but I'm not too sure about the B code. Going to take the battery and have it tested, although it always seems to start the bike without issue. I'm also going to check the grounds and have a look behind the fairing.
Anything else I'm missing?
Old Jul 21, 2017 | 08:04 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Have you got to the battery connection yet. Those two screws to the lead terminals of the battery tend to get loose. Battery vibrates a little tugging on the wires on most depending on how the wires are laid in there. My ground side wants to unscrew the bolt when the battery goes up and down on bumps. The battery is tied down with rubber and bumpers on most.
I just tweak the screws and it fixes most problems.
Old Jul 21, 2017 | 08:27 AM
K Melancon's Avatar
K Melancon
2015 Harley Diagnosis Codes
DTC’s from the 2015 Touring Models: Electrical Diagnostic Manual
Diagnostic Mode:
1 Press and hold the trip odometer reset switch, (trip Button) while turning the Ignition on.
2 Release the trip button and diag will appear on the odometer display
3 Press and release the trip button and ECM will appear on the odometer display. It will have a Y for yes or N for no depending if there are any ECM codes present
4 Quickly press and release the trip button to cycle through the modules. Modules include ECM, BCM, SPDO, ABS and Rad, (Engine Control Module, Body Control Module, Antilock Brake System, Radio).
5 Once the desired module is displayed press and hold the trip button.
6 If any DTC’s are stored the odometer will display the DTC. Quickly pressing the trip button will cycle through the stored DTC’s
7 When all DTC’s have been cycled through the odometer will display end.
8 To clear all DTC’s press and hold the trip button while a DTC is displayed.
9 Press and release the trip button to move to the next module.
10 Make note of all DTC’s. Operate bike to verify DTC’s are set and are current.
11 Turn Ignition off to exit diagnostic mode.
DTC’s are designated by a P,C,B or U
P codes indicate issues monitored by ECM
C codes indicate an issue with ABS
B codes are set by Radio, Instruments and BCM
U codes indicate a communication problems with the modules
B1103 LHCM Internal error
B1153 RHCM internal error
B1200 IM internal fault
B1210 Fuel level sender shorted low/open
B1211 Fuel level sender shorted high
B1212 Fuel signal low
B1213 Fuel signal high
B1300 Radio voltage high
B1301 Radio voltage low
B1302 Face plate home button stuck
B1303 Face plate favorite button stuck
B1304 Face plate navigation button stuck
B1305 Face plate power/mute button stuck
B1306 Rear hand controls shorted high
B1307 Rear hand controls shorted low
B1308 Rear volume up button stuck
B1309 Rear volume down button stuck
B1310 Rear mode button stuck
B1311 Rear PTT button stuck
B1312 Rear tune up button stuck
B1313 Rear tune down button stuck
B1314 LHCM VR button stuck
B1315 LHCM up button stuck
B1316 LHCM left button stuck
B1317 LHCM center button stuck
B1318 LHCM right button stuck
B1319 LHCM down button stuck
B1320 RHCM Info button stuck
B1321 RHCM up button stuck
B1322 RHCM left button stuck
B1323 RHCM center button stuck
B1324 RHCM right button stuck
B1325 RHCM down button stuck
B1326 RHCM CB squelch up button stuck
B1327 RHCM CB PTT button stuck
B1328 RHCM CB squelch down button stuck
B1329 Faceplate preset button 1 stuck
B1330 Faceplate preset button 2 stuck
B1331 Faceplate preset button 3 stuck
B1332 Faceplate preset button 4 stuck
B1333 Faceplate preset button 5 stuck
B1334 Faceplate preset button 6 stuck
B1335 Faceplate preset button 7 stuck
B1336 Faceplate preset button 8 stuck
B1337 Front left speaker shorted together
B1338 Front left speaker open
B1339 Front left speaker shorted low
B1340 Front left speaker shorted high
B1341 Rear left speaker shorted together
B1342 Rear left speaker open
B1343 Rear left speaker shorted low
B1344 Rear left speaker shorted high
B1345 Front right speaker shorted together
B1346 Front right speaker open
B1347 Front right speaker shorted low
B1348 Font right speaker shorted high
B1349 Rear right speaker shorted together
B1350 Rear right speaker open
B1351 Rear right speaker shorted low
B1352 Rear right speaker shorted high
B1353 Speaker offset DC output
B1354 GPS antenna open
B1355 GPS antenna shorted low
B1356 SDARS antenna open
B1357 SDARS antenna shorted
B1358 Front left headset shorted high
B1359 Front right headset shorted high
B1360 Front left headset shorted low
B1361 Front right headset shorted low
B1362 Rear left headset shorted high
B1363 Rear right headset shorted high
B1364 Rear left headset shorted low
B1365 Rear right headset shorted low
B1366 Internal thermal shutdown error
B1401 Amp voltage low
B1402 Amp voltage high
* Amp 1 Amp 2
B1403 Speaker offset DC output *
B1404 Internal thermal shutdown error *
B1405 EQ correlation error
B1406 Invalid or missing EQ
B1410 Channel 1 speaker open *
B1411 Channel 1 speaker shorted low *
B1412 Channel 1 speaker shorted high *
B1413 Channel 1 Speaker shorted together *
B1420 Channel 2 speaker open *
B1421 Channel 2 speaker shorted low *
B1422 Channel 2 speaker shorted high *
B1423 Channel 2 speaker shorted together *
B1430 Channel 3 speaker open *
B1431 Channel 3 speaker shorted low *
B1432 Channel 3 speaker shorted high *
B1433 Channel 3 speaker shorted together *
B1440 Channel 4 speaker open *
B1441 Channel 4 speaker shorted low *
B1442 Channel 4 speaker shorted high *
B1443 Channel 4 speaker shorted together *
B2102 System power output shorted high
B2103 System power output shorted low
B2104 System power output overloaded
B2106 L4 output open
B2107 L4 output shorted high
B2108 L4 output shorted low
B2109 L4 output overloaded
B2112 ACC output shorted high
B2113 ACC output shorted low
B2114 ACC output overloaded
B2116 Fuel pump output open
B2117 Fuel pump output shorted high
B2118 Fuel pump output shorted low
B2119 Fuel pump output overloaded
B2121 Starter output open
B2122 Starter output shorted high
B2123 Starter output shorted low
B2124 Starter output overloaded
B2127 E4 output shorted high
B2128 E4 output shorted low
B2129 E4 output overloaded
B2131 High beam output open
B2132 High beam output shorted high
B2133 High beam output shorted low
B2134 High beam output overloaded
B2136 Low beam output open
B2137 Low beam output shorted high
B2138 Low beam output shorted low
B2139 Low beam output overloaded
B2141 Left front turn signal output open
B2143 Left front turn signal output shorted low
B2144 Left front turn signal output overloaded
B2146 Right front turn signal output open
B2148 Right front turn signal output shorted low
B2149 Right front turn signal output overloaded
B2151 Left rear turn signal output open
B2153 Left rear turn signal output shorted low
B2154 Left rear turn signal output overloaded
B2156 Right rear turn signal output open
B2158 Right rear turn signal output shorted low
B2159 Right rear turn signal output overloaded
B2161 Brake lamp output open
B2163 Brake lamp output shorted low
B2164 Brake lamp output overloaded
B2168 Running lights output shorted low
B2169 Running lights output overloaded
B2172 H2 output shorted high
B2173 H2 output shorted low
B2176 Security antenna output open
B2177 Security antenna output shorted high
B2178 Security antenna output shorted low
B2183 G2 output shorted low
B2188 G3 output shorted low
B2193 H4 output shorted low
B2198 H3 output shorted low
B2201 IGN switch off w/VSS
B2203 Ignition switch input shorted low
B2206 Run/stop switch input open/shorted high
B2208 Run/stop switch input shorted low
B2210 Run/stop switch inputs both open
B2212 Run/stop switch inputs both closed
B2218 Neutral switch shorted low
B2223 Rear brake switch shorted low (light on)
B2226 BAS input open
B2228 BAS input shorted low
B2231 Fork locked/VSS
B2232 Fork lock shorted high
B2233 Fork lock shorted low
B2234 Fork lock detected with option disabled
B2235 Fork lock configuration invalid
B2250 Clutch switch stuck
B2251 Horn switch stuck
B2253 FTP switch stuck
B2254 Left turn switch stuck
B2255 Trip switch stuck
B2256 LHCM Police siren power stuck
B2257 LHCM Police siren wail power stuck
B2258 LHCM police siren yelp stuck
B2260 Start switch stuck
B2261 Right turn switch stuck
B2262 Front brake switch stuck
B2263 Hazard switch stuck
B2264 RHCM police lights power switch stuck
B2265 RHCM police lights front switch stuck
B2266 RHCM police lights rear switch stuck
B2267 RHCM police ICR switch stuck
B2270 BCM internal error
B2271 BCM voltage low
B2272 BCM/IM voltage high
B2274 Constant battery line error
C0562 ABS voltage low
C0563 ABS voltage high
C1014 ABS ECU relay error
C1021 ABS front WSS always zero
C1023 ABS rear WSS always zero
C1025 ABS Front wheel speed intermittent
C1027 ABS rear wheel speed intermittent
C1029 ABS wheel speed difference too high
C1032 ABS Front wheel speed circuit open/shorted
C1034 ABS rear wheel speed circuit open/shorted
C1040 ABS pump/motor error
C1055 ABS ECU internal error
C1061 ABS front apply solenoid circuit open/high resistance
C1062 ABS front release solenoid circuit open/high resistance
C1065 ABS rear apply solenoid circuit open/high resistance
C1066 ABS rear release solenoid circuit open/high resistance
C1071 Rear prime valve error
C1072 Rear isolation valve error
C1073 Front isolation valve error
C1074 Front prime valve error
C1075 Front linked inlet valve error
C1076 Front linked outlet valve error
C1077 Front circuit pressure sensor error
C1078 Rear circuit pressure sensor error
C1081 Front master pressure sensor error
C1082 Front master pressure sensor offset error
C1083 Front wheel pressure sensor error
C1084 Front wheel pressure sensor offset error
C1085 Rear master pressure sensor error
C1086 Rear master pressure offset sensor error
C1087 Rear wheel pressure sensor error
C1088 Rear wheel pressure sensor offset error
C1089 Pressure sensor external supply error
C1159 ABS invalid stored VIN
C1178 ABS no VIN received from ECM
C1184 ABS invalid VIN from ECM
C1195 Wake up error
P0031 Front HO2S low/open
P0032 Front HO2S shorted/high
P0051 Rear HO2S low/open
P0052 Rear HO2S shorted/high
P0072 AAT sensor low
P0073 AAT sensor high/open
P0107 MAP sensor failed low/open
P0108 MAP sensor failed high/open port
P0112 IAT sensor shorted low
P0113 IAT sensor high/open
P0117 ET sensor shorted low
P0118 ET sensor high/open
P0120 TPS 1 range error
P0122 TPS 1 low
P0123 TPS 1 high/open
P0131 O2 sensor low/engine lean (front)
P0132 Engine running rich (front)
P0134 Oxygen sensor High/open (front)
P0151 O2 sensor low/engine lean (rear)
PO152 Engine running rich (rear)
P0154 O2 sensor High/open (rear
P0220 TPS 2 range error
P0222 TPS 2 low/open
P0223 TPS 2 high
P0261 Fuel injector low/open (front)
P0262 Fuel injector shorted high (front)
P0264 Fuel injector low/open (rear)
P0265 Fuel injector shorted high (rear)
P0371 CKP sensor wrong number of pulses
P0374 CKP Sensor no pulses
P0444 Purge solenoid low/open
P0445 Purge solenoid shorted high
P0502 VSS failed low
P0503 VSS failed high
P0505 Idle speed control unstable
P0562 ECM voltage low
P0572 Brake switch low
P0577 Cruise control input error
P0603 ECM EEPROM memory error
P0605 ECM FLASH memory error
P0641 5 Volt reference out of range
P0651 5 Volt reference 2 out of range
P0691 Fan/cooling relay output low/open
P0692 Fan/cooling relay output high
P1009 VTD disabled fuel due to bad password
P1017 ET indicates overheating
P1019 ECT Difference (high temp)
P1270 TGS 2 A/D validation error
P1353 No combustion detected (front)
P1356 No combustion detected (rear)
P1475 Exhaust position actuation error
P1477 Exhaust valve actuator low/open
P1478 Exhaust valve actuator shorted high
P1501 JSS low
P1502 JSS high/open
P1510 ETC limited performance mode
P1511 ETC power management mode
P1512 ETC forced idle mode
P1514 ETC air flow error
P1600 ETC watchdog error
P1608 Loss of continuous battery
P1655 ACR solenoid low/open
P1656 ACR solenoid shorted high
P1691 Cooling fan left low/open
P1692 Cooling fan left shorted high
P1693 Cooling fan right low/open
P1694 Cooling fan right shorted high
P2100 ETC driver open circuit
P2101 ETC actuation error
P2102 ETC driver shorted low
P2103 ETC driver shorted high
P2105 ETC forced shutdown mode
P2107 ETC driver internal error
P2119 ETC actuator return error
P2122 TGS 1 low/open
P2123 TGS 1 high
P2127 TGS 2 low/open
P2128 TGS 2 high
P2135 TPS correlation error
P2138 TGS correlation error
P2176 ECT zero position learning error
P2184 ECT sensor low
P2185 ECT sensor high
P2300 Ignition coil driver low/open (front)
P2301 Ignition coil driver shorted high (front)
P2303 Ignition coil driver low/open (rear)
P2304 Ignition coil driver shorted high (rear)
U0001 CAN BUS error
U0002 CAN comm bus perf error
U0003 Network management monitoring
U0100 Lost comm w/ECM
U0121 Lost comm W/ABS
U0140 Lost comm W/BCM
U0141 Lost comm w/LHCM
U0142 Lost comm w/RHCM
U0156 Lost comm w/SPEEDO
U0158 Lost comm w/fuel gauge
U0159 Lost comm w/volt gauge
U0160 Lost comm w/ fuel and volt gauge
U0184 Lost comm w/radio
U0185 Lost comm w/Amp 1
U0186 Lost comm w/ AMP 2
U1302 ACC bus perf error
U1401 Lost com w/CB
Old Jul 21, 2017 | 09:39 AM
Black_Gold's Avatar
Black_Gold
Yes, I have checked them, to make sure they are tight.
Old Jul 21, 2017 | 09:40 AM
Black_Gold's Avatar
Black_Gold
Thanks, KM.
Old Jul 21, 2017 | 07:28 PM
K Melancon's Avatar
K Melancon
I keep a copy in my phone and a printed copy in my owners manual.
Old Jul 22, 2017 | 03:58 PM
Black_Gold's Avatar
Black_Gold
Finally got around to spending some time with it.
Had codes in every category, all u codes. Cleared the codes, then noticed that when I cranked the bars hard right (with the ignition on, engine off) it would get a check engine light. Checked the codes again and they were all back. Pulled the outer fairing off and poked/pulled at wires and nothing would throw a code. Pulled the main fairing off to check the wires coming from the handle bars (I had swapped the out several months and 2000 miles ago) and everything looked fine there. Started putting it all back together, checking for a code with each step and it all went back without any codes. I assume something was jostled around, causing it to bind when the bars were cranked. Going to test it out later tonight, once it cools off a bit.
EricJ
2014-2024 Touring Models
26
Apr 14, 2019 06:27 AM
Vernal
22
Oct 22, 2017 09:42 AM
JHC210
Milwaukee Eight (M8)
Oct 22, 2017 08:49 AM
Daddyo13
Jun 30, 2017 11:03 AM
I_JmpUJmp
Aug 1, 2012 02:24 AM
