FXSB Breakout Upgrade DIY: Fork Suspension / Tires / Brake -Part numbers, tools, tips
LA Dog, I plan on doing a fork mod in the near future. I'm curios why the Ricor site wants to sell me 10wt., When you clearly say use 5wt? Just want to make sure if I do it, which to use? Also I'm 160 lbs. ride one up 99% of the time, after experiencing your mod any recommendations what wt. springs I should go with?? and thanks..
LA Dog, I plan on doing this mod in the near future. I'm curios why the Ricor site wants to sell me 10wt., When you clearly say use 5wt? Just want to make sure before I do it, which to use? Also I'm 160 lbs. ride one up 99% of the time, after experiencing your mod any recommendations what wt. springs I should go with?? and thanks, your write up has me exited about the upgrade!!
5w oil
springs and part numbers are in this thread (Page 1, Post #1) just read it over again. You definitely want to do the springs and dampers at the same time.
oh yeah and scrap those crappy stock Breakout tires for the Pirelli Night Dragons. Yes it does make a huge difference on just about everything. not a little, a lot.
good luck - when you get it done post back and let me know how much it rocks.
SXR (02-03-2024)
Putting on the wider rear 260 tire is only going to make things worse as far as ride quality. A wider rear is the wrong thing to do for handling and braking especially on the BO. Your bike will not stop as well even though you'd think it would with a fatter tire. it will handle like a pig, and you've just added a lot more rotational mass (weight) with the wider thick tire. I'd really advise against it unless all you care about is having a really wide tire. that' all it's going to do for you
the narrower 120 front tire will definitely be an improvement.
**please don't be under any assumption that you will get anything close to the ride improvement benefits if you go with the 888's and a 260 rear - you will not!**
If you can avoid getting the 888's and do the ND's (in the correct sizes ) you'll be very pleased. Not only that, the ND's are priced pretty reasonable. I bought mine at motorcycle-superstore.com - good service, good prices. try amazon too.
Pirelli Night Dragon Front Tire
Color- Black, Size- 120/70-21 TL
SKU#394131 $135.99
Pirelli Night Dragon Rear Tire
Color- Black, Size- 240/40VR-18
SKU#255359 $191.99
$327.98 total, free ship. what' not to love
Too late for this time but you know about rear tires bad thing (or maybe good thing) is if you ride hard none of them last too long, Probably try the Pirelli next time even if I'm happy with the Metz. Just to try them out!!
Only be 8 to 12 months probably! Also I'm really hoping to just firm up the front and reduce the dip in turns.
only thing that is going to jack you up really is the 260 rear, being heavier and wider. with a wider tire you get less pounds per square inch of road contact, so it is easier for the tire to break loose. and it takes a lot more effort for turns. a bike will only brake as well as the tire has "Bite" with the road. if you do things to reduce the contact pressure then braking will suffer. with a narrower more apexed tire, the contact patch is smaller and there is more bite (more pounds per inch of contact area). Not saying all wide tires are bad, it comes down to what the bike was built / designed for. The BO is a softail designed for a 160/180 rear tire. HD did some mad wicked mojo and shoved a 240 up under there. so that is already pushing the limits.
SXR (02-03-2024)
