FXSB Breakout Upgrade DIY: Fork Suspension / Tires / Brake -Part numbers, tools, tips
Old 11-05-2015, 12:39 AM
Rocker B's Avatar
Rocker B
Rocker B is offline
You've given me some interesting ideas, definitely need do a little more research, but your recommendations make sense! doing the forks first should give me just enough time to figure out exactly what I want to do... Thanks again
  #42
Old 11-13-2015, 12:57 AM
Rocker B's Avatar
Rocker B
Rocker B is offline
LA Dog, about the gear/pulley mod, I thought I read somewhere where you said the 68t rear pulley fits easily and you could even fit a 70t if you wanted, still plenty of adjustment. I started thinking, what would happen to the final drive ratio if you just did a 70t rear and no change to the front or is that even a viable option? Would the 70t still fit with the 32t front? Maybe need a different size belt?
  #43
Old 11-13-2015, 08:50 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Off top of my head it would be about a 7.7% gain in TQ / ratio reduction. the hard part would be actually finding a 70t that fits the Breakout wheel. the belt *should* still work, but only way to know for sure is to try it. It would be a close call. I think it would be easier to do a 70t with a 30t front- that would be a hoot at almost 13%.
If you did the full enchilada and 30t front / 68t rear that gets you almost 10% and places the ratios back to the good ol' days before HD had to "tame" the ratios to meet fed and state req's. If you look at belt sprockets and final drive ratios on all HD bikes before say 1995 they were all geared much quicker. Any of the newer HD bikes will benefit from this upgrade. The bagger guys figured it out first which is where I got most of my intel. another member here from overseas had already done this to his BO and shared the correct rear sprocket P/N.
  #44
Old 11-13-2015, 12:50 PM
Rocker B's Avatar
Rocker B
Rocker B is offline
7.7% pretty good for a simple DIY if there's a 70t that will work!! I'll check it out.
  #45
Old 11-13-2015, 01:00 PM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
cool- yeh it will only be simple if the stock belt fits- it seemed it would but cutting it close.
  #46
Old 11-16-2015, 04:43 AM
Breakout Kid's Avatar
Breakout Kid
Breakout Kid is offline
2nd Gear
Great job on the bike. Great info.
Question do you still have a horn? It's gone in your pictures?
  #47
Old 11-16-2015, 07:57 AM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Thanks- I removed the horn and the front turn signals. I don't rely on them anyway.
Tell (03-03-2018)
  #48
Old 12-08-2015, 06:26 PM
notch.johnson's Avatar
notch.johnson
notch.johnson is offline
Hi LA Dog,
can you please confirm we need 49mm intiminators for FXSB? In the Everything Breakout thread you wrote 41mm.
Thanks!
  #49
Old 12-08-2015, 06:31 PM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Originally Posted by notch.johnson
Hi LA Dog,
Thanks!
Definitely a typo on my part in the BO thread. Everything on page #1 of this thread is 110% correct so please only use this specific thread as the "go-to guide" for parts ordering. Besides if you contact Ricor they are not going to sell you the wrong ones - Typo fixed!
SXR (02-03-2024)
  #50
Old 12-09-2015, 03:14 PM
LA_Dog's Avatar
LA_Dog
LA_Dog is offline
Here is a mod I posted on how to add the new super bright red LEDs to your tail light buckets. This is a 20 minute, easy mod with good results.
https://www.hdforums.com/forum/softa...l#post14647450
Quick Reply: FXSB Breakout Upgrade DIY: Fork Suspension / Tires / Brake -Part numbers, tools, tips
