The Everything 2018+ Heritage Thread
#1352
#1353
4 1/2 Pullback Riser install parts list
Just got finished installing 4 1/2 risers on my 2018 Heritage . Here is a part list of what I used.
Harley Davidson black pullback risers Part number 55900165
Upper clutch cable Part number 37200367 which is 36" long, if you want to use all stock mounting locations use the 37200380 at 38" long
Magnum shielding front brake line Part number AS47630 30" length
Magnum Shielding ABS adapter Part number AS47026
NAMZ wiring switch extensions plug - play Part number NHCX-J04 4"
NAMZ TBW extension Part number NTBW-J04 4"
You can go up to a 3 1/2 riser and keep all other parts stock, I just like the Harley Risers better.
I will try to post so pics up when the weather clears up. '
The following 2 users liked this post by pigfoot63:
A1A (03-15-2019),
Magnum Shielding (03-15-2019)
#1354
Risers
[QUOTE=pigfoot63;18105197]Just got finished installing 4 1/2 risers on my 2018 Heritage . Here is a part list of what I used.
What was the approximate cost and any problems installing. Also how much time did it take. I would like to add risers with pullback
#1355
I reckon it took about 4hrs, I am old and don't get in much of a hurry. The worst part was bleeding the front brake which is ABS took a few bleeds to get the air out.
If yo go with 3 1/2 risers you will only need the risers as the stock brake and clutch line will work, wiring is a little tight but you can work it out.
The new two piece cable was new to me and I suggest you read your service manual several times, I did have to readjust my clutch for free travel but it is
a very simple job once you understand it.
Total price for parts was 456.95 which you can beat by shopping on line. You can do the 3 1/2 in. set from Drag Specialities for around 150.00 or so.
#1356
I got 15k on front and rear. Coulda gone a little longer on both, particularly the rear but I decided to get new wheels and went ahead and got new tires at the same time. I went with the Michelin Scorchers this time. I haven't checked the tread depth but at 4k they still look like they are fairly new.
BCC1 (03-15-2019)
#1358
#1359
Tank bib gone
Reflectors on forks gone
Reflectors on saddlebags gone. (Need to find something to plug the holes with)
Waiting on halfmoon floorboards for momma and the v&h 2:1 propipe to show up
