Does your Low Rider rear brake suck?
I use my rear brake a lot. Mostly for slow speed maneuvering, combined with friction zoning the clutch, and for keeping the bike from rolling backwards on hills when stopped, etc.
I find the rear brake on my 2019 Low Rider to be abyssal. The 20 year old brake on my FXR is many, many times better. For example, when coming up the inclined driveway to my garage, I really have to stomp the pedal way harder then any past bike to keep the bike from rolling backwards.
Do any of you Low Rider owners feel the rear brake is as bad as mine?
Anyone use any improved third party calipers (ABS compatible)?
Thanks
Thanks
druski (04-10-2019)
Probably the same components. Thanks. Glad it’s not just me, but sad they would put something so bad on a new bike...
Reece Cofer (02-02-2020)
Mchad (04-07-2019)
Yes, it’s ABS, but since I now see two others who concur I doubt we all need a bleed. I think performance machine makes a caliper, but I’m not too keen on spending $500 on this. I’ll probably start with new pads first. I already put Lyndall gold pads in the front for a noticeable improvement. Maybe new pads will help here as well...
I'm not sure I would blame the caliper so quickly. Take a look at the horrible design of the rear brake lever. There is quite a bit of flex in the lever that never translates to pressure at the pushrod and master cylinder. The brake lever is not in line with the master. PS: mine is non abs and I have bled it. Good thing the front brake really clamps well even if it does sound like a French horn.
Slyvest (06-23-2020)
Can't speak to ABS since I don't have it, but raising the brake pedal helps a lot. See my post earlier today.
FWIW, if I had to choose between front and rear, I use the front brakes a lot more and the rear mostly to settle the chassis. This bike had a much better brake balance than my Dyna did in stock form. That one demanded you use the rear brake because the front was so awful. One man's opinion....
Las Vegas Jim (04-08-2019)
