2018+ Softail Models Breakout
new here 114 fat bob and brake question
Old 06-14-2019, 12:19 AM
slangklamman's Avatar
slangklamman
slangklamman is offline
Stage III
Default new here 114 fat bob and brake question
Hi all. my name is Janne and i am located in sweden. have a 19 114 fat bob. yesterday i put 13” la choppers kagefighter bars on my bike, had to put longer brakeline on, do i have to go to the dealer to blead the brakes? it is abs. have a vaccum bleeder and have run a bottle of fluid trough the system and hand bleed it. can i start the bike and go to the dealer or will the abs pump break if it is air still in the system?
Old 06-14-2019, 04:01 AM
FLS103's Avatar
FLS103
FLS103 is offline
I used a vacuum bleeder after doing a bar change on my 13 FLS with ABS and had no issues.
Old 06-14-2019, 06:03 AM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
Welcome to the forum, Janne.
You can bleed it with the vacuum bleeder like on a regulary bike without ABS, just leave the ignition off when doing this.
Old 06-14-2019, 07:17 AM
slangklamman
Stage III
thanks guys. i am so happy now. did the bleeding and it worked. totally diffrent bike now with the new bars.
ToraFatBob (06-14-2019)
Old 06-14-2019, 04:35 PM
Bowhunter8607's Avatar
Bowhunter8607
Bowhunter8607 is offline
What vacuum bleeder did you use? I've had a Mityvac hand pump vacuum bleeder and had issues with the fittings not sealing on the nipple in the past.
What did you use and how did you get the fittings/hoses to seal on the nipple to successfully bleed the brakes and not allow air back in?
Also can you briefly explain the bleeding process you used? Were you simply just using the vacuum bleeder or do you need to do a combination and pump the brake lever then hold it down and open the bleeder valve then pump the vacuum bleeder?
Sorry if this is a dumb question I just want to make sure I know how this is done since I've never had ABS on my bikes before.
Thanks.
Old 06-15-2019, 01:31 AM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
I'm doing this with a vacuum bleeder pretty much the same as pictured, no need for to touch the brake lever in this process. Keep in mind that you just bleed
the line and not the fluid in the ABS pump itself. I do both rear and front at the same time to get the most out of it but this procedure is only good for changing
the brakeline ( longer / shorter ) and not exactly for doing a brakefluid change.
Old 06-15-2019, 03:32 AM
slangklamman
Stage III
the vaccum bleeder i used is a cheap one that i hook up to a compressor. i bleed it trough with combination of pumping the brakes. i left it over night with a cabletie with the lever pushed in and then continued with only vaccum. i will never do this again i will do a reverse bleed if i need to change a line. that way the air never gets to the abs.
Fat Bey
08-04-2018 09:51 AM
musclehd
05-04-2017 12:55 PM
Psych0hans
06-29-2015 07:10 AM
PghSerb
08-16-2014 02:20 AM
toku58
06-10-2013 01:11 AM
Quick Reply: new here 114 fat bob and brake question
