Ventilator Air Cleaner Kit
I have a new 2019 Low Rider and ultimately want to do a Stage 1 conversion. But, I want to hold off until I have at least 1k miles on bike and until I can resolve my issues about the HD Pro Tuner. As a first step, I am considering adding the Ventilator Air Cleaner Kit (lowest flow of high flow options) to get a little more air to the engine. Questions:
1. Any feedback on adding just the Air Cleaner Kit?
2. How long should I wait to install it? (Should I go through some break-in period first?)
3. Is it necessary to reprogram the ECM if you just do the Ventilator Air Cleaner Kit without changing exhaust?
I have a new Street, didn't wait with the changes. As soon the bike was sitting in my garage with 0 miles on it I started with the changes I wanted, Vance & Hine FP3 & Big Radius with a aftermarket high flow filter
and all the other cosmetic stuff.
The bikes running lean as they came from factory, a highflow filter doesn't make that better, so I just put a FP3 on for starters with the High flow filter you want and you are good to go.
I traded a bike with an FP3, and I already miss it! (Harley would do well to acquire V&H and sell their products as HD OEM products. IMHO, the HD Pro Tuner is second-rate technology and isn't user friendly compared to the FP3.) Since I bought the bike new with 6 miles on it, I worry about the affect of the warranty by installing an FP3. From everything I read and hear, Harley is cracking down on the use of non-HD components, particularly FP3s. Are you worried about the affect on your HD warranty of installing an FP3 before the factory warranty period is over?
Are you ready for your warranty to be done? Or do you think the FP3's benefits outweigh the value of the remaining warranty? If so, go ahead. If not, don't do it.
Can you define "problem"?
Running lean from the factory seems to be a Twin Cam thing, not a M8 problem.
Power Vision puts an indelible print on the ECM, so flashing back to stock tune can be used for trouble shooting any problems but Harley factory can still detect that a tuner has been installed and void the warranty.
Las Vegas Jim (07-01-2019)
