2018 Sport Glide Addons
Sportglide18 (08-05-2019)
If you did everything at the same time, I would start with checking for an exhaust leak. Good looking bike and nice mods should be fun with the new cam. What extensions did you go with for the clutch and brake lines?
Dam bike been in shop about 3 times since mods for check engine light which turns out to be O2 sensor.
They have tuned it more than once and recently changed out sensors still having same error code I am so pissed.
Below are the part numbers on the paper work for the extension wires
KIT,HARN/WRG,EXTENSION 18 HD-69201804 and 69201794
Same problem
I'm having the same problem with engine light. Put rhinehart slipons, rhinehart breather, stage 2 torque kit and se tuner.. not even 4 miles from shop, engine light.. p131 and p151 code.. they cleared light but didnt fix because proper tech wasn't in.. said it wouldn't hurt bike to ride the **** out of it.. went about 50 miles then light again.. dropped off for 1000 mile service and for proper tech to address. Said it was fixed and test ridden.. didnt get 4 miles down the road and Bing! At least they showed me how to clear the damn light...will we watching to see if you get your fixed..
P0152 Rear Oxygen Sensor High / Engine Rich
even after 3 visits to the dealer.. On the 3rd and final visit, the tuner got it dialed in just right as the bike has not triggered the check engine light in the last 1.5K miles (knock on wood).. Keep pushing or find a really good tuner. A good AND knowledgeable tuner is difficult to find depending on where you live..
