2018+ Softail Models Breakout
error codes after handlebars and stage 2
Old Mar 4, 2023 | 09:13 PM
jmevis's Avatar
jmevis
2nd Gear
Default error codes after handlebars and stage 2
2021 Fatbob (FXFBS)
A week ago I did a stage 2 install, everything went smooth bike seemed to be running well. I uploaded a tune from my Powervision 3b (W screen) but didnt ride the bike more than 50 miles.
Cut to today, I wrapped up a handle bar install (10 pull backs and a low bend bar.) About 15 mins in to me running an auto tune on the power vision and ripping pretty hard on the interstate the bike dies, and basically can not start up. The power vision reads code and can clear them. So i tried to read them and clear them on the side of the road. Here are the codes.
P1608 - Loss of continuous battery.
Cleared the code and tried to start it up
then got
P0120 TPS 1 Range Error
P0220 TPS 2 Range Error
P1511 ETC Power Management Mode
Cleared the codes and tried to start it up
then got
P2122 TGS 1 Circuit Shorted to Ground
P2127 TGS 2 Circuit Shorted to Ground
Was able to start the bike (Maybe running on 1 cylinder) get it on a trailer how.
Should I start with a new twist grip sensor? I didn't touch the the throttle body during the install.
Old Mar 5, 2023 | 06:01 PM
stormin08's Avatar
stormin08
i would double check wiring under the tank and seat, check all connections real good.
then reflash the tune and go from there, hard parts should not have gone bad just from doing some motor work
Old Mar 5, 2023 | 06:33 PM
jmevis's Avatar
jmevis
2nd Gear
indid this today. no issues with connectors or anything like that. i unwired the bars then re wired them. calling fuel moto tomorrow morning to get a fresh tune since this happened during auto tune. bike won’t start still
Old Mar 14, 2023 | 03:09 PM
Stretchman's Avatar
Stretchman
I had something like this happen with a bar swap. The connector in the headstock, under the tank, has a couple of plugs that the bar wires can fit into. The key for me was opening the receptacle up and matching the color codes of the bar wires to the receptacle.
Just my 02, ymmv
Old Mar 14, 2023 | 03:23 PM
jmevis's Avatar
jmevis
2nd Gear
Just my 02, ymmv
so it actually ended up being a push rod issue.
the lock nut came loose and the push rod collapsed so it wasn’t opening the intake valve on the front cylinder.
Old Mar 14, 2023 | 03:42 PM
NZLowrider's Avatar
NZLowrider
oh no did it cause much damage?
Old Mar 14, 2023 | 04:28 PM
jmevis's Avatar
jmevis
2nd Gear
didn’t seem to cause any damage.
Old Mar 14, 2023 | 04:35 PM
jmevis's Avatar
jmevis
2nd Gear
julesdain
Canada
Nov 11, 2020 08:45 AM
flhs
Powdercoat & Paint
May 19, 2012 06:20 PM
JimmySG
Nov 29, 2011 10:43 AM
