Thought on Platinum Bleed feed after 6 weeks...
switches on handle bars
Yes you can I bought legend switches I think there the nicest looking and fit great but you need to have some knowledge on how to use a volt ohm meter to know which wires to put where in the plug so its still a plug and play system and they work up down in the correct position like I said if you know how to use a meter its easy
I’ve had the system for almost a year now. The honest truth. I hate it, after today’s 200 mile ride, I have to remove it. The ride is so inconsistent, it loose air after you hit bumps next thing your too low and it jars your back. So then you play around with it, and you have that sweet spot again. Then it bleeds down, after you hit some bumps.
I filled to full pressure,sprayed soap on water all over it, no leaks. It can sit on the lift at full pressure for hours no leaks. But as soon as you start hitting bumps, it’s bleeds down.
