Shotgun shocks in the way of transmission drain plug
Thanks for using shotgunshock. The trans drain plug is eaisly accessed without removing shock .Remove front two hex bolts and shock will pivot into verticle position.
Dropping front of shock,easier,faster
I ran allens shoulder bolts(look up good hardware house) and put flats on them Flats filed/milled to loosen & tighten and alen to spin out and on.I did this with other shocks,running pan motor and trans on softail,had to adjust primary chain the old way,sliding trans.Custom extras.......,extra time,money etc.Getting shotgunshock on the way on bike real soon.
with my extractor ( 1/4 hard plastic tube) shoved in across the trans gears to the bottom of the opposite side, and with the bike on its side stand, im able to pull out roughly 4-5 table spoons shy of whats suppose to go back in.. im good with that
and being that im using redline shockproof it REALLY doesnt make a difference
and being that im using redline shockproof it REALLY doesn't make a difference
Edit: Never mind, I didn't realize you had a factory 6 speed and the dipstick is in the tranny housing already and not the release cover like the 5 speeds...
