ASWC-1, Metra 99-9600 question
Gathering parts for an Kenwood HU, Biketronics 2180 and Biketronics 7.1 speaker install on a 13 SG. Have the Metra kit and the ASWC-1. Seems between the two I have more wire harnesses than I need? I'm guessing the one in the Metra kit is what I should use or am I missing something? Maybe when the head unit gets here tomorrow it will be obvious.
see picture below - I created the harness myself (some 1/4v inch plastic tubing I had laying around) but if you zoom in you will see this is the big HD radio plug from the metra kit and the axxess unit. the part you are missing in the picture is the HU connector... connection to the lose wires at the bottom... then also the "pink/white" cut line you need to ground.
see the sticky thread on this audio forum for programming instructions. https://cimg7.ibsrv.net/gimg/www.hdf...cda6390e69.jpg |
Originally Posted by Litewings
(Post 13371946)
Thanks for the info.
© 2024 MH Sub I, LLC dba Internet Brands
