"Bike" amp bench test results (initial batch 6 amps)
#52
So I have a question I can't seem to find the answer to, and I have searched...
Lets go with the RZ4-2000D Amp... 4 channels... So if I hook up the amp with 2ohm speakers on the front, and 4 ohm speakers on the rear... Does the amp differentiate between the two and run at 2ohms on the front channel (approx 147w) and 4 ohms on the rear channel (approx 97w)?? or is the am running at 2ohms front and rear??? Thanks in advance!
#53
#54
#55
for each channel? so each channel (front/rear) will sense and adjust? Just want to be clear. Thank you!
#56
#57
I have a 2010 Ultra with a kenwood hu, bt7.1 in fairing, Polk mm652 in lower fairing, Polk mm652 in the tour pack, Polk mm 692 in the lids. Right now each corner is wired in parallel, 7.1 to 6.5 in front and 6.5 to 6x9 in rear. What would amp or amps would work with this set up
But you will get your best/optimal sound if you had all alike speakers on their own Chanel.
