How do these two compare? The rms is lower on the Xdi but so is the sensitivity. I have a Rushmore with a PBR300 and looking for speaker options. I'm afraid that amp won't push the motos but will the Xdi be any better?
If you go with any of the Arc speakers you're gonna need a more powerful amp. The lower the sensitivity the more power you need for the speakers to get loud. With that amp you would be much better off with the Infinity 62.11i speakers @ 95db sensitivity.
Thanks for the info. Do you know if these will fit in the pods without rubbing or do I need to mount inside the pods? I had the kappas 65.11 and they touched the inner fairing.
Correction... My current speakers are the 62.11.
You have the speakers that GANN has suggested.
Infinity Kappa 62.11i
To keep the Kappas from hitting the grills they need to be mounted inside the pods.
If you can swing the $$ get the Biketronics speaker brackets. Those Kappas like open air in the fairing I am using the Kappas pushed with a SS PN4 1000D. I removed the back half of my pods and fabbed some support brackets for a test that I liked the results so much my sled is still that way.
