Scope pics and results
Using a good oscilloscope and a 1k test tone, amp hooked up to a 4 ohm(3.4 to be technical) resistive load I safely pulled 279 watts off the Arc 600.4 bridged. I was able to pull more but played on safe side. This is head unit at 33 of 35. Test yielded the Kenwood does not clip at all at max except at 35 on CD mode. At 34 it was close. On USB the preout level was only around 2 volts rms. In CD it didn't produce 4 till 33 on volume.
BAD https://cimg4.ibsrv.net/gimg/www.hdf...898a0776b5.jpg GOOD https://cimg5.ibsrv.net/gimg/www.hdf...695bea67b6.jpg Load https://cimg6.ibsrv.net/gimg/www.hdf...aad99bd81a.jpg |
Now there's something you don't see every day! Excellent job Slye!
Originally Posted by Gannicus
(Post 15115673)
© 2024 MH Sub I, LLC dba Internet Brands
