J&M amp running speakers in a series
My 2011 FLTRX that I bought used came with the J&M 7.25 fairing speakers and 2 channel amp and stock head unit. I'm adding lower fairing speakers soon and had a question about running the lower fairing speakers in a series? Anyone have any experience with this? I know it should reduce power to the speakers but any idea how much. I'm also thinking about just replacing the speakers while I'm at it with Polk 2 ohm 6.5s as well. So id be running 4 of those off the amp. I'm trying to save money and not have to buy everything new if I don't have to. Thanks in advance.
just my opinion.
Any suggestions on a decently low priced 4 channel amp? I'm leaning towards getting the polk mm 651 6.5" which is a 2 ohm speaker? Thanks for the reply!
http://www.sonicelectronix.com/lp/pl...PicaAkCu8P8HAQ
If you don't care about FM a decent low priced amp is here:
Kris
Lowebudget,
If you have one of the older ROKKER 2 channel amplifiers in your Streetglide the specs are 125W RMS per channel X2 into a 2ohm speaker load.
If you install this J&M performance series lower speaker kit http://www.jmcorp.com/ProductDetail....ctID=HLPS-7252 and connect it inseries using this inseries wiring harness http://www.jmcorp.com/ProductDetail....HLRK-7252-ISCH RMS power will drop to approximately 85W RMS per channel X2.
If you would rather install a 4 channel amplifier to power the system, here is a good reasonably priced J&M PERFORMANCE series 360W RMS amplifier that will preform very well for your application. http://www.jmcorp.com/ProductDetail....JMAA-3600H-UNV .
Let me know if you need the HD-Forums VIP Discount Promo Code.
__________________
JM-ANDY
J&M Corporation
1415 S. Cherry Ave.
Tucson, AZ 85713
Andy@Jmcorp.com
1-800-358-0881
For HD-Forums VIP Promo $$ discount code send email direct to Andy@Jmcorp.com
JM-ANDY
J&M Corporation
1415 S. Cherry Ave.
Tucson, AZ 85713
Andy@Jmcorp.com
1-800-358-0881
