2017 SG Speaker Upgrade Question
Hey All,
Be away for awhile, good to be back. Have a 2017 Street Glide Special now and am confused on some audio upgrades. I have an arc audio bx2 mini and set of 6.5 KS 6026 speakers from my previous 2009 Street Glide. I really would like to transfer this setup if possible but have read there may be some interference issues with the speakers and also may need to flash the radio. Arc list a 2014 and up harness for $45 that it appears I need as well. My questions are can I use these older speakers and do I need some type of flash? Thanks in Advance, Eagle Out |
If you are were happy with that set up on your last bike it will work on the new one. I would suggest getting the BT355 line leveler to avoid having to get a flash. I believe Arc has a flash recommendation for their MPAK setup, but the additional cost of the BT355 will be offset by not getting a flash. As far as the speaker you will probably just have to cut off the alignment knob for the stock speaker in order to get them on the outside of the pods.
Now that said, for about $500-700 you will blow away what you had on your old bike. |
© 2024 MH Sub I, LLC dba Internet Brands
