You will have a nice setup there. The Hertz are not bad speakers by any means. I really liked the ones you got off me, but if you haven't noticed I change partially as bad as Gann, Haze, T,etc. I say partially as a whole storefront of used audio is on them boys garage shelves.Did you get into your heads and what cams did you choose? That idle may keep you from listening to the audio while stationary!!!!
True Im trying to avoid the buy and resale trap
I have already done some of that. Just trying to keep it simple for now. If there is such a thing.
Had the heads C&C running a 2.10 intake and stock 1.63 Exhaust but Upgraded to Manley valves and AV&V guides. 110's are hard on Valves and guides
Custom springs built for .625 lift
Flowed good @ lift 9 -314
Also sent the heads and jugs to Nevada and got them Diamond Cut
Just did a S&S 570 Cam for now. May try High lift cam down the road
Hope to get it on the dyno in April. I have the tune done fro the most part
