Fairing install pics
I was wondering if anyone that has the biketronics amp breakout harness had any pics without the fairing on? I have tried it in a couple different places and it is causing clearance issues. I have a day lighter headlight, so there's less room, but the harness wires are so short, I can't touch it in beside the HU where I have plenty of room...
Thanks in advance. Shane |
2 Attachment(s)
Originally Posted by camoglide
(Post 16077067)
1 Attachment(s)
This was taken prior to hooking the rest of it up and cleaning up wires and such. It's the only pic I took with the fairing off but we ended up moving the breakout harness from where it is in the picture to the spot under the wiring on the BT amp and over the main harness of the radio. Used a few zip ties to keep it in place but you are correct- that harness takes up a TON of space. It took me and Pete 3 hours to get everything tucked in and the fairing back on, a quarter inch at a time. On. Off. On. Off. What a pain. You'll get it in there!!
Attachment 520393 |
Thanks guys! Really appreciate it!
I'm curious how you mounted the DD AW6.5 speakers without using the Biketronics Speaker Brackets that everyone tells me I should use at a cost of $225.00.
Thanks! |
© 2024 MH Sub I, LLC dba Internet Brands
