Auxiliary problem? 3.5 mm plug in
Hi am a disabled Iraq veteran with a traumatic brain injury and reason I say that is that I not that technical or hard for me to explain things so here goes but I bought the accessory kit to add a 3.5 mm output or input for xm radio and even have same problem with ipod too but when I use either one I can't get the volume as loud as my fm/am .radio The volume is lower even inn my headset. If I switch from my xm to regular radio it is lot louder, when they put my accessory on at the hd dealer they didn't know how to fix it, so is it just me or does others have the problem of so can it be fixed thanks
Originally Posted by Dsm Limited
Not to sound ridiculous, but i have to ask. Are you turning up the volume on the devices you are plugging into the auxiliary jack? I use to use a similar setup and remember having to turn up the volume on my portable xm receiver.
And thank you for your service!!!!!!!
Happens all the time so check that first. Welcome to the Audio Forum and damn I cannot thank u enough for your service my friend!!!!!!
If the source volume is not the problem, no worries as we will get to the bottom of this issue.
T.
