Big thank you to alex/bal!
Little late but finally got around to it. Finished it up last Friday, DD 6.5's/BT 28's with an ARC audio 600.4 and BT/LL in the fairing. Rear is Pioneer Pro 6900's with a Sound Stream TN4.900D. The best part of this whole build is that with the help from this forum and obviously BAL, I was able to do the install and tune myself and I could not be any happier! The bike sounds awesome and the install is pretty clean for the first time. Please don't tell anyone that the tweeters are not staggered for better sound! Yep that's right I drilled it wrong ordered another one and drilled it wrong again, so it is staying for the time being!!
Both AMPS are bridged ARC to the fronts and SS to the back. Gains are set on the conservative side. Can turn the system all the way up and there is zero distortion.
Also if it helps I would have thought the SS in the bag would have gotten very hot but turns out after 300mi it was just slightly warm to the touch!
