2017 Street Glide S
Old 05-18-2017, 10:45 AM
17SGS's Avatar
17SGS
17SGS is offline
Stage III
Default 2017 Street Glide S
Hello, brand new to the forum. Picked up a 2017 Street Glide S earlier this year and have been enjoying it. 2 things I have not liked and in the process of changing is the wind buffeting and the sound system. I have previously always had softtails with windshields and no buffeting.
Anyways....got a 10" windshield and lower fairings, bam buffeting gone. The sound system still leaves something to be desired. I am not trying to go all out crazy on this, but would like some better sound.
I am looking to replace the fairing speakers and possibly put speakers in the lower fairings and add an amp. I would love to stay around the $500-$1000 price range if that helps. Any helpful tips, pointers, advice? Thanks in advance!
Old 05-18-2017, 11:12 AM
cpbedor's Avatar
cpbedor
cpbedor is offline
Advice is to hold off a little bit and save some cash for a bigger budget. 4 speakers and an amp and all the peripheral items needed to install it is going to yield you nothing but disappointment and it will then be $500 down the drain when you redo it. It's surely possible to slam something in there for 500 but you're spreading your cash pretty thin at that point. Gannicus will be around shortly to deliver his budget friendly opinion, stay tuned.
Old 05-18-2017, 01:08 PM
17SGS's Avatar
17SGS
17SGS is offline
Stage III
Default Edit
Edit I meant to say $500-$1000...just looking for ideas. I have seen some people do 2 small JL amps and 4 moto speakers...just not up to speed on latest greatest on what all works with the new bikes. Ex: do I need a alternator upgrade, do i need a new EQ....which by the way reminds me...will different speakers and amps get rid of the sound quality difference between ign on bike running vs ign on bike not running???
To put into laymans terms-> I like the sound quality of my bike on the show room floor cranked up. If I could get it to sound the same w/similar volume and clarity at 75mph I would be happy!
Old 05-18-2017, 01:30 PM
matt76cmich's Avatar
matt76cmich
matt76cmich is offline
Well, to get the same sound as you do with the bike off while it's running you have 3 options in my mind and I'll go from cheapest to most expensive. Just throwing some speakers and amps in the bike won't solve this problem.
1. JL Fix82/86. This is an easy fix, but can be a tough install in the newer batwing fairings. Put it in a bag and no worries.
2. Arc Audio PSM (or a different full DSP). Easy to install anywhere on the bike (Arc PSM that is), but if you don't know what you're doing tuning wise you can easily screw things up (or keep messing with it till you get it, but could take days to weeks)
3. Aftermarket radio. Biketronics has a single din kit that you can get with a radio and everything needed to retain handlebar function. Or people have been going with the Sony 100 something or another double din (can't remember the model number right off hand). This kit comes with the radio and everything needed to install it and retain handlebar controls.
Now 1 and 2 will be very close in price depending on where you get them and if it's setup to be plug and play for your bike. Basically looking at $380-799 and that'll eat up a big chunk of the budget. A cheaper solution is the Biketronics BT355 line leveler that will help flatten the eq curve, but won't solve the on vs off bin file.
Also, your stock 50 amp stator will be more than good enough to power your system.
Old 05-19-2017, 08:50 AM
duglaura&flhti's Avatar
duglaura&flhti
duglaura&flhti is offline
Congrats....Biketronics makes a nice replacement speaks
Old 05-19-2017, 02:53 PM
17SGS's Avatar
17SGS
17SGS is offline
Stage III
Default Arc Audio
What do you guys think about this system, add 2 more speakers and a DSP? How is this compared to say BOOM stage 2 audio? will this get rid of the bad EQ setting while bike is running?
Old 05-19-2017, 07:10 PM
Gannicus's Avatar
Gannicus
Gannicus is offline
That set up will blow the boom system away but for the cost you can do much better! Give Haze a shout. Alex@baggeraudio.com
Old 05-23-2017, 09:42 AM
DeluxeCruiser's Avatar
DeluxeCruiser
DeluxeCruiser is offline
subscribed for reference.
NoSecCatfish
Audio Systems
03-21-2019 08:23 PM
NoSecCatfish
Audio Systems
135
02-16-2019 02:42 PM
NC_RIDER
Audio Systems
08-19-2016 01:43 PM
WestTexasRanger
Audio Systems
27
02-26-2016 10:15 AM
lyork
2014-2023 Touring Models
50
12-15-2014 01:40 PM
Quick Reply: 2017 Street Glide S
