Cerwin Vega Question
I just installed a Cerwin Vega B52 Amp this weekend as part of a system upgrade. After I got everything powered on and tested, I noticed it was running a bit hot. So this morning I finished up the install and took it for a ride. After I got home (about 1 hour later), the front fairing was warm to the touch.
My question is, do these amps run hot? If so, what have you guys done to prevent any damage from the heat?
The B52 amp is getting it's signal from the BT355 line leveler and only powering a set of AD CX62 in the rear. As far as adjustment, I turned the main volume to just shy of 4 clicks and them adjusted the SENS till the rear speakers fluttered. Once they fluttered, I backed it off a tad.
From the sounds of it, I might have it turned up too high? If I back it down, I really don't get much from the speakers. Any ideas?
TexasD (06-20-2017)
