Are crossovers still needed with a DSP?
I've been reading up a little on crossovers in regards to crossover points and the marriage (if you will) of components.
You have 2 types of what I'll call external crossovers, passive (after the amp) and active (before the amp).
If you're controlling these audio components through the DSP, are external crossovers still needed?
That would be a Active crossover
The Passive crossover should be what you replace . (External)
And to clarify Passive means its a physical device with coils and filters, it can go anywhere inline, and requires no power
Active is a device that requires power.
I would say THE DSP would replace both types
But depends on the capability's of the DSP
shortride
08-22-2010 04:58 PM
