Change out my J and M Rokkers or go to a bigger amp?
Price wise the SS, the PP seem pretty reasonable around $150 or less. The Cerwin Vega B-52 is around the same and the B-54 is around $200. Amazing how much prices can vary between Canada and the US. Saved $100us even after paying $90 for duty and express shipping on the Kappas and pioneer speakers by ordering them south of the border.
Looking forward to those speakers showing up this week. Do the HD grills in the rear pods fit over those pioneer grills? If not, what do you recommend for grills, doesn't look like the pioneers offer much protection.
Also wandering about the J and M sound deadning material I have in the fairing, ok to leave it, better to remove it, worth putting in dynamat?
Rockford PBR amps currently connected with RCA's. Read somewhere, they work better with the high level inputs off the HU. Currently using a Sony HU. Better to continue using the RCAs or switch to High levels off the HU to the RF amp
Bluesman280 (07-18-2017)
Thanks for the offer on the grills, I should be able to find something laying around town at one of the install shops, if not I will let you know.
Speakers arrived yesterday. Wont have time for a couple days to tackle the fairing or the lowers, but I already installed the Pioneers in the rear pods.
What a huge difference over the Sony 5.25" 2 ways I had in there.
Was pleasantly surprised when I hit the highway to run a couple errands and could feel the thump of the pioneers on my back.
Looking forward to installing those Infinity speakers, and replacing the speakers in the lowers.
Speakers showed up and I m coming down the home stretch. Is it best to wrap those Infinity speakers in the fairing with poly fill and should it be loosely wrapped or fairly snug. Currently I have it fairly snug, with a band of electric tape around outside edge of the Scoche adapters to hold it on. The speakers are quite loud but seem a bit dull. Even after adjusting the EQ they seem a bit dull, but that could be partially because the 4 pioneer Tsa 1686 are quite a bit brighter. Wondering if I should leave it like that or open the fairing again and loosen up the poly fill. not sure how much the poly fill could be effecting the tone.
Sony MEX 70bt settings
EQ set to Explode or Electronic. Leave the adjustable EQ settings alone.
HPF set to 80 Slope 1
DSEE set to on
Loudness (AAV) OFF!!!!!!!!!
Hey Sbates, Thanks for the info on settings.
Sounds better already.
Looking forward to the road test, unfortunately we had a heavy rain storm blow in just as I got everything finished up.
DSEE set to on
Everything is sounding way better, but getting a little more distortion at the high end of the volume level than I like, and that's where I seem to gravitate to at highway speeds.
Most likely caused by the limitations of the 2 PBRs im running everything off of now.
Planning on the SS PN4.1000D or the PPI depending on price and availability.
Do I need anything extra to mount either of these amps in the fairing or does it fit right on top of my Sony HU. Currently one of the PBRs sits on the HU, the second is bolted to a hog tunes amp bracket that mounts on the left side beside the speaker and replaces the old fairing bracket. Will I need any brackets or does it fit right on top of the head unit.
nukidondablock
Audio Systems
22
10-11-2018 08:31 AM
