Help needed Kappa Install! 2013 FLHTK
Originally Posted by reno55
Thanks for the input....I ordered the wrong adapters ugh!
So I took advantage of their 0% interest for 6 months and went with Rockford TMS6SG instead of the Kappa's
Not sure the model # of the scoche adapters that you have, but I have used the scoche adapters in my 2005 Batwing fairing and they work fine.
The part# I used was SAHD656. I haven't tried them with the Kappa's yet, but have used them with other 6.5" speakers. Kappa's on order, should be here in a couple days.
Your install shop has me concerned if they were not able to figure it out that the factory HD grills can remain in place. That is all I used with the Scoche adapters I used.
Good Luck
Good Luck
There is only 3 screw mounting holes with the Scoche adapter to avoid any issues with the bottom inside screw, but I can definitely understand the concern.
Hopefully they are smart enough to figure it out, or follow the instructions.
That's too bad. I know the Scoche rings work fine if used properly, that is what I currently have in my bike. Scoche products were all I could find locally when I did my install on my batwing, I see the metra adapters seem to be more available online, and they look to have more mounting holes and seem to be much more versatile than the Scoche adapters.
So the shop is installing my audio upgrade and they are saying the Kappa's cannot be installed into the factory mounts. I did provide them the Scoshe adapters but now they are saying there will be a big hole with no grill one the front of the speaker.
Has anyone who installed kappa's in front fairing on a 2013 FLHTK run into this?
I attached a photo of what it looks like
This is how they should look o the viewing public.
Added the infinity logo from the kappas for looks.
Your install shop is clueless and reckless
