Kappas with no amp.
Kappas with no amp.
I've got two pair of Kappa 62.11i speakers for my "14" Limited. While I'm waiting to get an amp (living on a budget lol) I'd like to install these and see if I can get just a little better sound from my stock system. Will the Kappas sound any better than the stock speakers without an amp to drive them?
The reason I ask is because I did install a set of JBL Gx602 speakers in the front fairing... they literally sounded worse than the stock. The level of sound from them was considerably lower than the stock speakers and when increasing the volume to get the same loudness level they distorted terribly. Needless to say i took them back out and reinstalled the stock speakers. I don't want to waste time putting the Kappas in if I'm going to have the same problem.
Thanks for your advise.
Originally Posted by Gannicus
No Sir. Gotta have an amp.
As G mentioned, if ur gonna take the leap into aftermarket there really is no shallow end in this pool.
Ur gonna need a BT Line Leveler and an amp for sure.
Other possible work arounds for the BT LL but that is the most proven method for the masses to date and also keeps it plug and play into your factory harnesses.
T.
The following 2 users liked this post by Gannicus:
rockymtman (07-26-2017),
Toucan2442 (07-28-2017)
Thanks for the advice everyone. I will get an amp and longer levelers and necessary wiring/hardware before I install the Kappas. I've been doing my research on amps and the SS PN4 1000d is a popular choice to pair with these Kappas especially for the price but there needs to be some modifications to the stock amp tray.
Are there any other suggested amps in the same price range that will work without doing any mods?
but the b54 fits much easier, and definately is no slouch with those speakers
